Acer X113PH SVGA DLP 3000 Lumens Projector
Quicklinx: 9NFQWS00 Mfr#: MR.JK611.002
Whether you're projecting business presentations, academic lectures or photographs, draw your audience in with immersive 3D. Colors remain balanced and images accurate with advanced Acer technologies. Everything looks sharp and real thanks to exceptional resolution and high brightness.
Launch right into your concepts with a customized startup screen. Modify power, viewing and timer settings with the one-touch empowering key. Broaden your viewpoint by instantly projecting wide-format content without complicated resolution tinkering. And you can safely unplug as soon as the projector is off.
  • Captivating
  • Flexible
  • Convenient
    Display your ideas just how you want with keystone correction. Pan across presentations and zoom in on important points. Attach multiple devices via dedicated connectors. Lamp replacement is simple, even when the projector is ceiling mounted, with the easy access of an excellent design.
  • Eco-smart
    Acer EcoProjection reduces power in standby mode to as little as a single watt to conserve energy and protect the environment. Earth-friendly elements include long lamp life for lower replacement cost and dependable use, an eco mode, and automatic sleep or shutdown after a pre-set period.
Acer X113PH - DLP projector - portable - 3D
DLP projector
3D Capable
United Kingdom, Europe
Brightness
3000 ANSI lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
P-VIP 190 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
AC 120/230 V
235 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.5 kg
DLP projector
3D Capable
Projector
Brightness
3000 ANSI lumens
Brightness (Reduced)
2400 ANSI lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
58.4 cm - 762 cm
Projection Distance
1 m - 11.9 m
Throw Ratio
1.95 - 2.15:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 190 Watt
Bulb life cycle
BrilliantColor, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, Acer ColorSafe II Technology
Lens
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
GS, FCC, ROSTEST
AC 120/230 V
235 Watt
Power Consumption Stand by
0.5 Watt
31.4 cm
22.3 cm
9.3 cm
2.5 kg
Sound Emission
31 dBA
28 dBA
