Acer X110P DLP 3D Ready SVGA Projector - 2700 ANSI Lumens
Quicklinx: 7H5YWS00 Mfr#: EY.JBU01.039
The Acer X110 value projector showcases highly detailed projection performance even on colored walls. Setting up is easy with handy installation utilities, and power-management solutions yield great energy savings.
  • Brilliant display
    The SVGA resolution of the X110 presents sharp, accurate details. Colors are vivid and natural with Acer ColorBoost II+ technology, 2500 ANSI lumens brightness, and 4000:1 contrast ratio. And ColorSafe technology prevents color decay to preserve the integrity of your images even after prolonged use of the projector.
  • Presentation flexibility
    With keystone correction up to 40 degrees, the X110 displays images without distortion. With the installation menu, signal input from a notebook is no longer required to enable the OSD menu, making projector installation on the ceiling faster, easier and more convenient.
  • Enhanced usability
    The Empowering key on the remote gives you instant access to quick customization of power, viewing and timer settings. The wall-color compensation feature enables accurate display of colors even when the image is projected on a colored wall. And with closed captioning, dialog and non-speech audio can be displayed as text to facilitate comprehension.
  • Ecological functionality
    Acer EcoProjection technology cuts power in standby mode from 5 W to 1 W, to conserve energy, that's up to 80 percent power savings! Other eco-conscious technologies include a power-saving eco mode, and automatic shutdown after a pre-set period without signal input.
Acer X110P - DLP projector - portable - 3D
DLP projector
3D Capable
Brightness
2700 lumens
Contrast Ratio
4000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
P-VIP 180 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
(NTSC, SECAM, PAL)
Video Modes
1080p
2.2 kg
DLP projector
3D Capable
Projector
Brightness
2700 lumens
Brightness (Reduced)
2000 lumens
Contrast Ratio
4000:1
Image Size
762 cm
Projection Distance
1 m - 11.9 m
Resolution
SVGA - SVGA (800 x 600) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 100 kHz
Bulb type
P-VIP 180 Watt
Bulb life cycle
ColorBoost II+ Technology
Lens
Lens Aperture
F/2.41-2.55
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Video Modes
1080p
2.2 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
