Form plus functionality is increased with a modern look, small form factor chassis, increased ventilation grills and a an elegant design.
Expandability is key
Future proof your business needs with extra storage bays, PCIe slots and discrete graphics cards. -
Increase your viewing space
Increase your viewing space and maximize productivity as you extend your desktop across as many as five monitors. -
Control your workspace
Find a convenient place for your Veriton with the flexibility of being able to power your PC on and off from the monitor.
- Acer Veriton X2 VX2660G - SFF - Core i5 8400 2.8 GHz - 8 GB - SSD 256 GB
- Personal computer - small form factor
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 256 GB
- Optical Storage
- DVD-Writer
- Card Reader
- Graphics Controller
- Intel UHD Graphics 630
- Audio Output
- 5.1 channel surround
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Windows 10 Pro 64-bit Edition
- 10.2 cm x 30.508 cm x 33 cm
- 5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in
- Personal computer
- Product Form Factor
- Small form factor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.8 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Manufacturer
- Kingston
Storage Controller
- 1 x SATA
Optical Storage
- DVD-Writer - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, HDMI, DisplayPort
Audio Output
- Sound Output Mode
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111
- Data Link Protocol
- Remote Management Protocol
- DMI
- Wake on LAN (WoL), PXE support
- Slots
- 1 (total) / 1 (free) x PCIe x16 , 2 (total) / 2 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in (1 rear) , 4 x USB 2.0 , 2 x USB 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x HDMI , 1 x DisplayPort
- Included Accessories
- 2.5" HDD metal bracket with toolless kit
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), chassis intrusion alarm
- Security Slot Type
- Kensington security slot
- BSMI, CB, FCC, RoHS, EuP
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 180 Watt
- Efficiency
- 82%+
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
Sustainability Information
- ENERGY STAR Certified
- 10.2 cm
- 30.508 cm
- 33 cm
- 5 kg
