Acer Veriton X2660G Core i5-8400U 8GB 256GB SSD Windows 10 Pro
UP TO A POSSIBLE £100 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: F3J3WS00 Mfr#: DT.VQWEK.028
  • Core i5
  • Expandability is key
    Future proof your business needs with extra storage bays, PCIe slots and discrete graphics cards.
  • Increase your viewing space
    Increase your viewing space and maximize productivity as you extend your desktop across as many as five monitors.
  • Control your workspace
    Find a convenient place for your Veriton with the flexibility of being able to power your PC on and off from the monitor.
Acer Veriton X2 VX2660G - SFF - Core i5 8400 2.8 GHz - 8 GB - 256 GB
Personal computer - small form factor
Region: United Kingdom
1 x Intel Core i5 (8th Gen) 8400 / 2.8 GHz (4 GHz) (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x SSD 256 GB
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
Intel UHD Graphics 630
Audio Output
5.1 channel surround
GigE
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
10.2 cm x 30.508 cm x 33 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Max Turbo Speed
4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 256 GB
Manufacturer
Kingston
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, HDMI, DisplayPort
Audio Output
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support
Slots
1 (total) / 1 (free) x PCIe x16 , 2 (total) / 2 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI
1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in (1 rear) , 4 x USB 2.0 , 2 x USB 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x HDMI , 1 x DisplayPort
2.5" HDD metal bracket with toolless kit
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
BSMI, CB, FCC, RoHS, EuP
Power supply
Nominal Voltage
AC 120/230 V
Power Provided
180 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
ENERGY STAR Certified
10.2 cm
30.508 cm
33 cm
5 kg
