Acer Veriton X2640G Core i5-6400 4GB 1TB Windows 10 Pro
Quicklinx: CM16WS00 Mfr#: DT.VMXEK.023
  • Core i5
The Acer Veriton series offers value desktop computing in compact packages. With excellent multitasking performance, Veriton systems have the powerful manageability and security features needed for enterprise deployment.
  • Form and function
    The Veriton 2 series delivers excellent multitasking performance to optimize your productivity. Tool-less expandability, a selection of affordable solutions, and other useful features efficiently handle your daily work needs.
  • Vital security
    With support for WOL, PXE and more, the Veriton 2 series is simple to manage.
Acer Veriton X2 VX2640G - SFF - Core i5 6400 2.7 GHz - 4 GB - HDD 1 TB
Personal computer - small form factor
Region: United Kingdom
Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
Graphics Controller
Intel HD Graphics 530
1GbE
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
10 cm x 35.4 cm x 26.5 cm
6 kg
Personal computer
Product Form Factor
Small form factor
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
DIMM 288-pin
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Bays
Internal 3.5" , External 5.25"
Slots
1 (total) / 0 (free) x CPU , DIMM 288-pin , 1 PCIe x1 , 1 PCIe x16
4 x USB 2.0 (2 front, 2 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x microphone (1 in front) , 2 x audio line-out/headphones (1 in front) , 1 x audio line-in , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x DVI , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EuP
Power supply
AC 120/230 V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
10 cm
35.4 cm
26.5 cm
6 kg
