Acer Veriton N466OG USFF Ci5-9400T 8GB 128GB SSD Windows 10 Home
Quicklinx: FYF9WS00 Mfr#: DT.VRDEK.06K
  • Core i5
  • IEEE 802.11n
  • The Perfect Fit for Your Business
    Adjust your PC to the size and demands of your business with the modular design of the Veriton N Series.
  • Tower Power
    Push through a tough work day with the performance quality and vital safety features your business requires.
  • Growing With Your Business
    Build your desktop as you build your business with easily attachable 1-litre add-ons.
  • Breathe Easy
    Designed for efficiency, the new ventilated chassis helps keep your Veriton N running cooler, longer.
  • Ideal placement
    Free up your workspace and work more effectively with the sturdy support of the VESA mount.
  • Easy Internal Access
    Simply slide open the chassis for quick access to the HDD, M.2 SSD and memory without the hassle of additional tools.
  • Powerful Processing
    Easily run highly intensive processing tasks and applications with an 8th Gen Intel Core i7+ processor with vPro.
  • Bring It All Together
    Deliver wireless presentations from your laptop with business partners around the world using Intel Unite.
  • Keep a Healthy PC
    Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator.
  • Strong on Security
    The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
  • Compact yet flexible design for the classroom
    Featuring a tiny 1-litre chassis, Veriton N series desktops can lie flat on the desk, be set upright be attached behind the monitor to save even more space.
  • Optimal performance
    Whether in the classroom or in the lab, the Veriton N series provides the processing power schools need to run a wide range of applications thanks to latest generation Intel Core processors and up to 16 GB of DDR4 memory.
  • Effortless class management
    Veriton N desktops run Windows 10 Pro, which offers a familiar interface and app compatibility, while enabling new collaboration models and project-based learning, to help students develop 21st century skills.
Acer Veriton N4 VN4660G - compact PC - AI Ready - Core i5 9400T 1.8 GHz - 8 GB - SSD 128 GB
Personal computer - compact PC AI Ready
Region: United Kingdom
Intel Core i5 (9th Gen) 9400T / 1.8 GHz (, up to 3.4 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
SSD 128 GB
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
OS Provided
Windows 10 Home 64-bit Edition
19.2 cm x 20.4 cm x 3.32 cm
1.5 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in
Personal computer - AI Ready
Product Form Factor
Compact PC
Processor / Chipset
CPU
Clock Speed
1.8 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 128 GB
Manufacturer
Kingston
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111EPV
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Bluetooth 5.0
Remote Management Protocol
DMI
Wake on LAN (WoL), PXE support
Slots
1 (total) / 1 (free) x PCIe x16 , 3 M.2 Card
2 x USB 2.0 , 3 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C 3.1 , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front)
VESA mounting kit, 2x wireless aerials, ADP holder for VESA kit
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion alarm
Security Slot Type
Kensington security slot
TUV GS, BSMI, CB, FCC, RoHS, PC 2001
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Sustainability Information
ENERGY STAR Certified
19.2 cm
20.4 cm
3.32 cm
1.5 kg
