Acer Veriton N4640G USFF i5-7400T 4GB 500GB Win 10 Pro 64-bit
Quicklinx: DQMSWS00 Mfr#: DT.VQ0EK.020
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Core i5
  • IEEE 802.11n
£435.04 ex VAT
£522.04 inc VAT
Looking for a creative solution to your limited workspace? The compact Veriton N Series packs generous processing power, manageability and security features into a 1-liter design perfect for space-restricted settings.
  • Breathe easy
    Designed for efficiency, the ventilated chassis helps keep your Veriton N running cooler, longer.
  • Ideal placement
    Free up your workspace and work more effectively with the sturdy support of the VESA mount.
  • Easy internal access
    Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools.
  • Kensington Security Slot
    The Kensington Security Slot is an anti-theft system that allows for one end of a security cable to be locked into a reinforced hole on the device while the other end is attached to a stationary object for additional device security.
  • Keep a healthy PC
    Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator.
  • Strong on security
    The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
Acer Veriton N4 VN4640G - tiny - Core i5 7400T 2.4 GHz - 4 GB - 500 GB
Personal computer - tiny
Region: United Kingdom
1 x Intel Core i5 (7th Gen) 7400T / 2.4 GHz (3 GHz) (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x 500 GB - SATA 6Gb/s - 5400 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
24.95 cm x 20.4 cm x 5.95 cm
1.5 kg
Personal computer
Product Form Factor
Tiny
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Manufacturer
Seagate
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek 8111EPV
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Slots
1 PCIe x16
4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x HDMI
Wireless antenna, VESA mounting kit
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VCCI, BSMI, GS, CB, FCC, RoHS, PC 2001
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
24.95 cm
20.4 cm
5.95 cm
1.5 kg
Acer Veriton N4640G USFF i5-7400T 4GB 500GB Win 10 Pro 64-bit Bundle deal on Acer Veriton N4640G USFF i5-7400T 4GB 500GB Win 10 Pro 64-bit
£620.26
saving £8.33
£534.21
DQMS Crucial DDR4 - 16 GB: 2 x 8 GB - SO-DIMM 260-pin - 2400 MHz In Stock £57.96
Storage Type: HDD
Processor Model: I5-7400T
Type: Personal computer
Case Style: Ultra small form factor
Optical Storage: None
Brand: Acer
Price Range Ex VAT: 300 - 500
