The Veriton series is ready to meet various business needs. With a powerful processor and fast memory, serious performance is delivered. High manageability fuels business growth.
Breathe easy
Designed for efficiency, the ventilated chassis helps keep your Veriton N running cooler, longer. -
Ideal placement
Free up your workspace and work more effectively with the sturdy support of the VESA mount. -
Easy internal access
Simply slide open the chassis for quick access to the HDD, M.2 SSD, and memory without the hassle of additional tools. -
Kensington Security Slot
The Kensington Security Slot is an anti-theft system that allows for one end of a security cable to be locked into a reinforced hole on the device while the other end is attached to a stationary object for additional device security. -
Keep a healthy PC
Know when components are not functioning properly and avoid system failures with the Acer System Health Indicator. -
Strong on security
The hardware-level Trusted Platform Module is serious security for any business that is serious about security.
- Acer Veriton N4 VN4640G - tiny - Core i5 7400T 2.4 GHz - 4 GB - SSD 256 GB
- Personal computer - tiny
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i5 (7th Gen) 7400T / 2.4 GHz (, up to 3 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 256 GB - M.2 2280
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- Windows 10 Pro 64-bit Edition
- 19.2 cm x 20.4 cm x 3.32 cm
- 1.5 kg
- Personal computer
- Product Form Factor
- Tiny
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.4 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 7265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- 1 (total) / 0 (free) x CPU , SO-DIMM 260-pin , 1 PCIe x16 , 1 PCIe
- 4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x HDMI
- Included Accessories
- Wireless antenna, VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- RoHS
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 19.2 cm
- 20.4 cm
- 3.32 cm
- 1.5 kg
