The Veriton 6 series comes in a wide range of form factors to meet various business needs. Intel Core processors and fast DDR3 memory deliver serious performance, while a premium software suite offers security and manageability to drive business efficientc.
Form and function
The Veriton 6 series is designed to fit all office spaces and business demands. Perform more tasks at once with powerful processors plus fast memory. -
Reliable, convenient
The solid capacitor design provides the stability, reliability and longevity essential to meet the power needs of the high-end processors and other components in the Veriton 6 series, enabling them to run demanding applications. A convenient, modular design allows components to be easily swapped or upgraded.
- Acer Veriton M6 VM6640G - MT - Core i7 6700 3.4 GHz - 8 GB - HDD 1 TB
- Personal computer - mini tower
- Localisation
- Region: United Kingdom
- Processor
- Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- NVIDIA GeForce GT 705
- Video Memory
- 1 GB
- Networking
- GigE
- Power
- AC 120/230 V
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition / Windows 10 Pro 64-bit Edition Dual Load
- 17.5 cm x 42.95 cm x 37.65 cm
- 9 kg
- Personal computer
- Product Form Factor
- Mini tower
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q170
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 1 GB
- Video Interfaces
- VGA, DVI, HDMI
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Data Link Protocol
- Bays
- 5.25" , 3.5"
- Slots
- DIMM 288-pin , 1 PCI , 2 PCIe x1 , 1 PCIe x16
- 6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) , 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-I , 1 x HDMI
- RoHS, EuP
- Power supply
- Voltage Required
- AC 120/230 V
- Power Provided
- 300 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- 17.5 cm
- 42.95 cm
- 37.65 cm
- 9 kg
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
