Acer V6 Series V196WL 19" 1440 x 900 5ms VGA DVI LED Monitor
Quicklinx: 8NTHWS00 Mfr#: UM.CV6EE.001
Explore the angle that's perfect for you with this professional series monitor, which tilt, swivel, pivot and adjust for height to achieve the optimal position for extended viewing. Ergonomic designs provide handsome style on your desk - or off: these monitors are wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of professional series monitors. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Flexible
    Find the working angle that's perfect for you with a monitor that tilts, swivels, pivots and can be adjusted for height. The stand also has a magnetic area, perfect for holding paperclips and keeping your desk uncluttered. This monitor is also wall-mountable, giving you clear views with more room.
  • Brilliant
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitor. Plentiful built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, and more realistic colors.
  • Connective
    Collaborating with others is faster and more productive when you have ample ports available. Professional series monitor allows you to connect to a wide variety of devices like notebooks and tablets, thanks to VGA port.
  • Ecological
    Professional series monitor is RoHS compliant and mercury free. In addition, the advanced Acer EcoDisplay design plus white LED backlighting yield significant power savings. More than 10% of the material used in this monitor is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer V196WL - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
AC 120/230 V
43.94 cm x 19.05 cm x 37.85 cm
3.1 kg
3-year warranty
Display Type
Diagonal Size
19"
Aspect Ratio
16:10
Native Resolution
1440 x 900 at 60 Hz
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
43.94 cm x 19.05 cm x 37.85 cm - with stand
3.1 kg
VGA
1 x VGA cable
Input Voltage
AC 120/230 V
Power Consumption (Typical)
13 Watt
Power Consumption Stand by
450 mW
Dimensions & Weight Details
Without stand - weight: 2.7 kg
Limited warranty - 3 years - carry-in
