The Full HD resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment. Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings.
Full HD LED monitor
The Full HD resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment. -
Acer EcoDisplay
Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. -
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. -
Acer eColor Management
A single button - the empowering key - gives full access to the Acer eColor Management on-screen interface. Acer eColor Management provides a variety of advanced controls for achieving high image quality.
- Acer V276HLCbmdpx - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Matte black
- 63.97 cm x 24.2 cm x 46.34 cm
- 5.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- RoHS, TUV Rheinland
- 3-year warranty
- Display Type
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 31 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma, 72% NTSC colour gamut
- Matte black
- 63.97 cm x 24.2 cm x 46.34 cm - with stand
- 5.2 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI , VGA , DisplayPort , Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable - VGA to VGA - 1.5 m
- MTBF
- 30,000 hour(s)
- Input Voltage
- Power Consumption (Typical)
- 26.6 Watt
- Power Consumption Stand by
- 0.24 Watt
- Power Consumption Sleep
- 0.43 Watt
- Dimensions & Weight Details
- With stand - width: 63.97 cm - depth: 24.2 cm - height: 46.34 cm - weight: 5.2 kg , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
