Acer V276HLCbid 27" 1920x1080 VGA DVI HDMI Monitor
Quicklinx: CPFTWS00 Mfr#: UM.HV6EE.C05
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: DVI, HDMI, VGA (HD-15)
More than 50 in stock
£105.49 ex VAT
£126.58 inc VAT
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment.
  • Full HD LED monitor
  • Acer EcoDisplay
    Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of the commitment to sustainable operations and CSR, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
  • ComfyView
    Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
  • Acer eColor Management
    A single button - the Empowering Key - gives full access to the Acer eColor Management on screen interface. Acer eColor Management provides a variety of advanced controls for achieving the best-possible image quality.
Acer V276HLCbid - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
63.97 cm x 24.2 cm x 46.34 cm
Environmental Standards
ENERGY STAR Qualified
RoHS, TCO Displays 6.0, TUV Rheinland
3-year warranty
Display Type
Energy Class
Class B
47 kWh
32 W
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma
63.97 cm x 24.2 cm x 46.34 cm - with stand
DVI , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
Stand
1 x VGA cable - VGA to VGA
Power Consumption Stand by
430 mW
Power Consumption (Off Mode)
240 mW
Dimensions & Weight Details
With stand - width: 63.97 cm - depth: 24.2 cm - height: 46.34 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer V276HLCbid 27 Bundle deal on Acer V276HLCbid 27" 1920x1080 VGA DVI HDMI Monitor
£204.66
CPFT StarTech.com Dual Monitor Mount - Stackable In Stock £146.29
CPFT StarTech.com Cubicle Monitor Hanger In Stock £45.29
CPFT StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
CPFT StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
CPFT StarTech.com Monitor Desk Mount - Steel In Stock £32.85
Diagonal Size: 27in
Response Time: 6ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 100 - 150
