The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment.
Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CCFL lamps. Plus, this monitor is mercury free, making it safer for you and the environment. -
Acer EcoDisplay
Acer monitors using white LED backlight technology minimize environmental impact while providing superior performance. White LED monitors do not contain mercury, making them safer for the environment. They also consume less power and are more durable than CCFL lamps, for good savings. Plus, as part of the commitment to sustainable operations and CSR, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact. -
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods. -
Acer eColor Management
A single button - the Empowering Key - gives full access to the Acer eColor Management on screen interface. Acer eColor Management provides a variety of advanced controls for achieving the best-possible image quality.
- Acer V276HLCbid - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 47 kWh
- Power Consumption (On mode)
- 32 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 63.97 cm x 24.2 cm x 46.34 cm
- Environmental Standards
- ENERGY STAR Qualified
- RoHS, TUV Rheinland
- 3-year warranty
- Display Type
- Energy Class
- Class B
- 47 kWh
- Diagonal Size
- 27"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Acer eColor technology, 6-bit gamma
- Black
- 63.97 cm x 24.2 cm x 46.34 cm - with stand
- DVI , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable - VGA to VGA
- Input Voltage
- 32 W
- Power Consumption Stand by
- 430 mW
- 240 mW
- Dimensions & Weight Details
- With stand - width: 63.97 cm - depth: 24.2 cm - height: 46.34 cm , Without stand - width: 63.97 cm - depth: 6.18 cm - height: 38.09 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
