Brand
Acer V247Ybip 23.8" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: G0J9WS00 Mfr#: UM.QV7EE.016
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: VGA (HD-15), HDMI, DisplayPort
£117.26 ex VAT
£140.71 inc VAT
Acer’s 24" V247Y monitor is a commercial monitor, designed to meet your day-to-day business needs.
Complete Peace of Mind
All of Acer’s commercial & professional monitors come with Acer’s 3 year commercial warranty, giving you complete peace of mind that the V247Y will be reliable.
Protect Your Vision
Acer’s VisionCare suite of technologies are designed for protected your vision, especially when viewing a monitor for extended periods of time, such as a full workday. BlueLightShield minimises harmful blue light that cause eye strain as well as interfering with people’s sleep patterns, Flicker-Less eliminates screen flickering which can exacerbate fatigue caused by viewing the screen for long periods and ComfyView is an anti-glare finish that minimises reflections to make the screen easier to view.
Acer ZeroFrame
The V247Y features Acer’s ZeroFrame design, which slims down the bezels for a sleek, professional style. As well as helping the monitor to look nice, it also means it’s a great choice for multi-monitor set-ups, allowing for enhances productivity without thick, unsightly bezels between the screens.
IPS Panel
The V247Y also features an IPS panel, which allows it to produce more vivid colours and higher contrast, which helps content displayed on the screen to appear sharper; as well as supporting wider viewing angles which is great for when you’re collaborating with a colleague or showing a client what you’ve been working on.
  • Sustainably Designed
    Our Vero monitors are designed to give you a more sustainable choice in displays. This monitor is built with 35% PCR plastics, features 100% recyclable packaging, and is TCO, ENERGY STAR, and EPEAT Silver certified.
  • A Sight to Behold
    Take productivity to the next level with 4K ultra-high definition resolution. Text, images, and more will be crisp and clear for a more enjoyable user experience.
  • Vivid Visuals
    Whether choosing photos or editing videos, the 90% DCI-P3 color coverage with up to 1.07 billion colors and HDR10 support give you more precise colors and enhanced color depth to bring out all the details of your work.
  • Protecting Your Eyes
    This display comes equipped Acer VisionCare eye-protecting technologies such as Acer BlueLightShield, Flickerless, Low-dimming, and ComfyView.
  • Adaptive Sync
    With Adaptive Sync, the monitor's framerate is synced with your graphics card, eliminating screen tearing and delivering ultra-smooth video playback.
  • The Perfect Angle
    Tilt and utilize a VESA mount on this monitor to always have a perfect angle to view your content.
Acer V247Y bip - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class F
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
54 cm x 19.6 cm x 42.4 cm
4.4 kg
EMEA
Environmental Standards
TCO Certified Displays 8 EPEAT Bronze
3-year warranty
Display Type
Energy Class
Class F
32 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
ComfyView, Zero Frame, 3-sided bezeless, 72% NTSC colour gamut
54 cm x 19.6 cm x 42.4 cm - with stand
4.4 kg
VGA , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MTBF
30,000 hour(s)
EMEA
Input Voltage
22 W
21.8 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.39 Watt
Power Consumption Sleep
0.27 Watt
Power Consumption (Off Mode)
0.27 Watt
Shipping Weight
6.5 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Bronze
Limited warranty - 3 years
20 - 80%
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Acer
