Acer V247Ybip 23.8" 1920x1080 4ms VGA HDMI DP LED Monitor
Quicklinx: D9ZVWS00 Mfr#: UM.QV7EE.004
Select:
  • 23.8"
  • Designed for Comfort
    Find the perfect position for your viewing needs with this sturdy yet flexible design.
  • What a View
    Get the most out of your viewing experience with high-resolution colours and innovative eye-care technology.
  • More Screen to See
    The ZeroFrame bezel design with narrower borders offers more space for viewing.
  • A View for All
    Share your screen with every corner of the room as colours stay true no matter what angle you're viewing from.
  • Flexible Stability
    Relax at the perfect viewing angle with the adjustable tilt function and improved stand stability.
  • The Beauty of Sound
    Set the tone with full, vibrant audio from the on-board dual speaker sound system.
  • All for 4K
    Once you've sat in front of a 4K screen, you'll never settle for less. See the difference with the splendour of 4K.
  • Care for Your Vision
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
  • Settings, Your Way
    Take control of customisable display settings, split-screen options and more with the easily accessible Acer Display Widget.
Acer V7 Series V247Ybip - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Matte black
54 cm x 19.6 cm x 42.4 cm
4.4 kg
France
Environmental Standards
TCO Certified Displays 8
3-year warranty
Display Type
Energy Class
Class A
32 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Pixel Per Inch
92.6
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Finnish, Russian, Spanish, Dutch, Chinese
Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 72% NTSC colour gamut
Matte black
54 cm x 19.6 cm x 42.4 cm - with stand
4.4 kg
VGA , HDMI , DisplayPort
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable , 1 x DisplayPort cable
MTBF
30,000 hour(s)
France
Input Voltage
22 W
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.27 Watt
Power Consumption Sleep
0.39 Watt
Power Consumption (Off Mode)
0.27 Watt
Dimensions & Weight Details
Without stand - width: 54 cm - depth: 6.5 cm - height: 42.4 cm , With stand - width: 54 cm - depth: 19.6 cm - height: 42.4 cm - weight: 4.4 kg
Shipping Weight
6.5 kg
Sustainability Information
TCO Certified
Limited warranty - 3 years - on-site
20 - 80%
