Explore the angle that's perfect for you with this monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Its ergonomic design provides handsome style on your desk - or off: this monitor is wall-mountable, giving you clear views with more room. The contrast ratio of the monitor is superior and the response is ultra-quick. IPS technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. Moreover, the monitor allows you to connect to a wide variety of useful devices including notebooks, tablets, and giant screen TVs, thanks to helpful connectivity options.
Adaptable
Explore the angle that's perfect for you with this monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Ergonomic design provides a handsome style on your desk - or off: this monitor is wall-mountable, giving you clear views with more room. -
Convincing
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of this monitor. IPS technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. -
Plenty of ports available
Collaborating with others is faster and more productive when you have plenty of ports available. This monitor allows you to connect to a wide variety of useful devices including notebooks, tablets, and giant screen TVs, thanks to helpful connectivity options. -
Green focus
This monitor is mercury-free. In addition, you'll see power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the Earth's resources. Acer also uses recyclable packaging to further reduce ecological impact.
- Acer V246HQL bi - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/402204
- Energy Class
- Class F
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 27 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.7 cm x 20.68 cm x 42.12 cm
- 3.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV, ICT
- Display Type
- Energy Class
- Class F
- 39 kWh
- Diagonal Size
- 23.6"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, eColor Management, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Mercury free, Acer eColor technology, 6-bit gamma, Low Blue Light Content
- Black
- 56.7 cm x 20.68 cm x 42.12 cm - with stand
- 3.9 kg
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable
- TUV, ICT
- Input Voltage
- 27 W
- Power Consumption SDR (On mode)
- 20.4 kWh/1000h
- Power Consumption (Typical)
- 20.3 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 56.7 cm - depth: 20.68 cm - height: 42.12 cm - weight: 3.9 kg , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm - weight: 3.49 kg
Sustainability Information
- ENERGY STAR Certified
