Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Bright colors, sustainable vision
- 24" Full HD Acer ComfyView display with Acer eColor technology
- Earth-friendly: recycled plastic, LED backlight, Acer EcoDisplay
- Extensive connectivity: VGA and DVI
- 100 million: 1 contrast ratio
The Acer V246HL display features Acer eColor technology that makes every pixel clear and colorful on the non-glare 24'' screen. Together with White LED Technology, V6 series, ensures exceptional reliability and great savings as well as a better performance.
Tilt design of this display ensures the best viewing angle at daily operation. Besides, the V6 displays have thin body and grooves design on the tray of base to put your stationary on.
The Acer V246HL display delivers vibrant visuals and comfortable viewing ideal for business users.
- Acer V246HL - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 22.1 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 56.7 cm x 20.68 cm x 42.22 cm
- 3.9 kg
- Localisation
- United Kingdom, Europe, EMEA
- Display Type
- Energy Class
- Class F
- 34 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, Acer EcoDisplay
- Black
- 56.7 cm x 20.68 cm x 42.22 cm - with stand
- 3.9 kg
- VGA , DVI
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Localisation
- Input Voltage
- AC 120/230 V
- 22.1 W
- Power Consumption SDR (On mode)
- 22.1 kWh/1000h
- Power Consumption (Typical)
- 20.9 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.5 kg
