Find the perfect position for your viewing needs with this sturdy yet flexible design. Get the most out of your viewing experience with high resolution colors and innovative eye care technology. The ZeroFrame bezel design with narrower borders offers more real estate for viewing.
Designed for comfort
Find the perfect position for your viewing needs with this sturdy yet flexible design. -
What a view
Get the most out of your viewing experience with high resolution colors and innovative eye care technology. -
More screen to see
The ZeroFrame bezel design with narrower borders offers more real estate for viewing. -
A view for all
Share your screen with every corner of the room as colors stay true no matter what angle you're viewing from. -
Flexible stability
Relax at the perfect viewing angle with the adjustable tilt function and improved stand stability. -
All for 4K
Once you've sat in front of a 4K screen, you'll never settle for less. See the difference, with the splendor of 4K. -
Care for your vision
Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience. -
Settings, your way
Take control of customizable display settings, split screen options and more with the easily accessible Acer Display Widget.
- Acer V227Qbip - V7 Series - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/397354
- Energy Class
- Class F
- Energy Consumption per Year
- 30 kWh
- Power Consumption (On mode)
- 21 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 (DisplayPort: 75 Hz, VGA: 60 Hz, HDMI: 75 Hz)
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.97 cm x 18.55 cm x 39.559 cm
- 3.53 kg
- Environmental Standards
- TCO Certified Displays 9 EPEAT Bronze
- Display Type
- Energy Class
- Class F
- 30 kWh
- Diagonal Size
- 21.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 48 - 76 Hz
- Horizontal Refresh Rate
- 30 - 85 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM), Grayscale Viewing, Super Sharpness technology, 6-axis Hue, 6-axis Saturate
- Black
- 48.97 cm x 18.55 cm x 39.559 cm - with stand
- 3.53 kg
- HDMI , VGA , DisplayPort
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable
- Input Voltage
- 21 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption Sleep
- 0.25 Watt
- 0.23 Watt
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Bronze
- 5 °C
- 35 °C
- 20 - 80%
