Acer V226HQLbid 21.5" 1920x1080 5ms VGA DVI HMDI LED Monitor
Quicklinx: G0JJWS00 Mfr#: UM.WV6EE.028
The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD multimedia and productivity applications. LED monitors also consume less power and last longer than those with CCFL lamps. Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
  • Full HD LED monitor
    The 1920 x 1080 resolution of this LED monitor delivers excellent detail, making it perfect for advanced HD multimedia and productivity applications. LED monitors also consume less power and last longer than those with CCFL lamps. In addition, this monitor is mercury-free, making it safer for you and the environment.
  • ComfyView
  • Acer eColor Management
    A single button - the empowering key - gives full access to the Acer eColor Management on-screen interface. Acer eColor Management provides a variety of advanced controls for achieving the best-possible image quality.
Acer V226HQL bid - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397341
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
50.8 cm x 20.68 cm x 39.05 cm
3.66 kg
Environmental Standards
EPEAT Bronze
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
50.8 cm x 20.68 cm x 39.05 cm - with stand
3.66 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
Input Voltage
26 W
19 kWh/1000h
Power Consumption (Typical)
16.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.68 cm - height: 39.05 cm - weight: 3.66 kg , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm - weight: 3.24 kg
Sustainability Information
EPEAT Compliant
EPEAT Bronze
