Acer V226HQLbd 21.5" 1920x1080 5ms VGA DVI  Monitor
UP TO A POSSIBLE £200 CASHBACK AVAILABLE - SEE PRODUCT FOR MORE INFO
Cashback
Quicklinx: CPG4WS00 Mfr#: UM.WV6EE.005
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
50.8 cm x 20.68 cm x 39.04 cm
3.66 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
32 kWh
22 W
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM)
3.66 kg
VGA , DVI (HDCP)
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
AC 120/230 V
19.5 Watt
Power Consumption Stand by
350 mW
Power Consumption Sleep
250 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - weight: 3.24 kg
ENERGY STAR Certified
