Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
- Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/397341
- Energy Class
- Class F
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 19 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 20.68 cm x 39.04 cm
- 3.66 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- Display Type
- Energy Class
- Class F
- 32 kWh
- Diagonal Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM)
- Black
- 3.66 kg
- VGA , DVI (HDCP)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 19.5 Watt
- Power Consumption Stand by
- 350 mW
- Power Consumption Sleep
- 250 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - weight: 3.24 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
