Acer V226HQLB 21.5" 1920x1080 5ms DVI LED Monitor
IDEAL FOR YOUR OFFICE, STUDIO OR STUDY!
Quicklinx: 9LBMWS00 Mfr#: UM.WV6EE.B04
Everyday series monitors give you the beauty you appreciate and the value you need. They showcase captivating widescreen visuals as well as eco-conscious features, making them perfect for enjoying marvelous multimedia at home or in your office, studio or study.
  • Designed to adapt
    V6 Series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room.
  • Bright and clear
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Very connected
    Collaborating with others is faster and more productive when you have plenty of ports available. V6 Series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports.
  • Eco focus
    V6 Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer V226HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
19 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Voltage
AC 120/230 V
50.8 cm x 20.68 cm x 39.04 cm
3.66 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
32 kWh
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
HDCP
3.66 kg
VGA , DVI
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MPR II
Input Voltage
AC 120/230 V
19 W
19 kWh/1000h
Power Consumption (Typical)
18.1 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - weight: 3.24 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
9LBM StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
9LBM StarTech.com Articulating Monitor Arm In Stock £132.69
9LBM StarTech.com Dual Monitor Stand In Stock £91.00
9LBM StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
9LBM StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
