Acer V226HQLAbmd 21.5" 1920x1080 8ms VGA DVI Speakers LED Monitor
Quicklinx: 900JWS00 Mfr#: UM.WV6EE.A09
Essential Series monitor let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. This monitor is also wall-mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Designed to adapt
  • Bright and clear
  • Very connected
    Collaborating with others is faster and more productive when you have plenty of ports available. Essential Series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports.
  • Eco focus
    Essential Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
Acer V226HQLAbmd - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class F
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Integrated
Voltage
AC 120/230 V
50.8 cm x 20.68 cm x 39.04 cm
3.66 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class F
32 kWh
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
50.8 cm x 20.68 cm x 39.04 cm - with stand
3.66 kg
Audio
Speakers - integrated
Output Power / Channel
1 Watt
VGA , DVI (HDCP)
1 x VGA cable
Input Voltage
AC 120/230 V
22 W
19 kWh/1000h
Power Consumption (Typical)
19.5 Watt
Power Consumption Stand by
350 mW
Power Consumption Sleep
250 mW
On / Off Switch
No
Dimensions & Weight Details
Without stand - weight: 3.24 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
900J StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
900J StarTech.com Articulating Monitor Arm In Stock £132.69
900J StarTech.com Dual Monitor Stand In Stock £91.00
900J StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
900J StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
