Acer V223WE 22" 1366 x 768 5MS Analog
Quicklinx: 7DS8WS00 Mfr#: ET.EV3WE.E22
The Acer V223W series is the essence of versatile productivity, bringing to the professional office and media world the perfect combination of high definition performance within a slim design format for the ultimate viewing experience.
The V223W series combines the advanced Widescreen Panel technology, efficient lean design with full consideration of high display performance per pixel, this is an irresistible opportunity to join the widescreen trend for PC displays. The V223W series provides the ideal technical features required for multi-tasking and image precision, the intelligent 22" widescreen display supports also the latest operation systems which require high definition pixel per inch for specialized professional applications. The V223W series is truly a cost-effective solution driving versatile performance for media lovers and professional business environments.
  • Text precision and rich color
    Images are reproduced with speed and precision thanks to an adaptive dynamic contrast ratio of 50,000:1 and response rates of only 5ms.
  • View 34% more data or media content
    View 34% more data or media which has a 53% larger viewable display size than a standard 17" LCD, creating a real return on investment and excellent cost per pixel.
  • Acer eDisplay for advanced and easy display enhancements
    The V223W series comes with an intuitive eDisplay system for advanced color calibration and display adjustment. Easy to navigate and adjust, also with the on screen display function so you can select the best set up for the particular work modes.
  • Detailed PPI (pixel per inch)
    The dazzling P223W hits the perfect pixel level supporting professional applications requiring high PPI content, a comfortable land on term view.
Acer V223WEObd - LCD monitor - 22"
LCD monitor - 22"
Panel Type
TN
Native Resolution
1680 x 1050 at 60 Hz
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
50.6 cm x 18 cm x 39.9 cm
4.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
22"
Panel Type
TN
Native Resolution
Pixel Pitch
0.282 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
HDCP, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
4.6 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable
Power Supply
Internal
Power Consumption (Typical)
20.7 Watt
Power Consumption Stand by / Sleep
0.46 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
