The V223HQ is a solid 16:9 format display which brings to the home a perfect balance between best value performance and the full high definition technical features for home media and cinematic applications. Thanks to the 16:9 format cut you can view your photos or movies over a broader cinematic area for a thrilling experience. The V223HQ is a brilliant display reproducing crisp data and media over a cinematic format with the added benefits of a higher resolution performance. In addition, the aesthetically pleasing design portrays a contemporary style that easily integrates into any modern home or work environment.
Text precision and rich color
Images are reproduced with speed and precision thanks to an adaptive contrast ratio and response rates of only 5ms. -
View 34% more data or media content
View 34% more data or media which has a 53% larger viewable display size then a standard 21.5" LCD, creating a real return on investment and excellent cost per pixel. -
Acer eDisplay for advanced and easy display enhancements
The V223HQ comes with an intuitive eDisplay system for advanced color calibration and display adjustment. Easy to navigate and adjust, also with the on screen display function so you can select the best set up for the particular work modes. -
Energy saving and environmentally friendly
The professional V223HQ display consumes less energy then any standard display, also tested and compliant according to the Energy Star 4.0 standards for low power usage in on/off and sleep mode. -
Detailed PPI (pixel per inch)
The dazzling V223HQ hits the perfect pixel level supporting professional applications requiring high PPI content.
- Acer V223HQBOb - LCD monitor - Full HD (1080p) - 21.5"
- LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 50000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- VGA
- Tilt
- Black
- 50.8 cm x 19.5 cm x 37.2 cm
- 4.5 kg
- Localisation
- United Kingdom, Europe, EMEA
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, ISO 9241-307
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 50000:1 (dynamic)
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 80 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 176
- Backlight Technology
- CCFL
- Four Lamps for Back Light, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
- Black
- 4.5 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, CCFL (cold cathode fluorescent lamp)
- MTBF
- 50,000 hour(s)
- Localisation
- Power Supply
- Internal
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by / Sleep
- 0.67 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years - carry-in
