Essential series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
Productivity in focus
Essential Series monitors feature Acer eColor technology for striking visuals, and Acer ComfyView innovations that reduce glare to deliver most-comfortable viewing. These sturdy monitors also have a wide array of ports, so you can connect many types of devices and do more at once. In addition, they utilize eco-friendly features to save power and money.
- Acer V196L - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/367870
- Energy Class
- Class F
- Power Consumption (On mode)
- 17.5 W
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 75 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 40.64 cm x 20.7 cm x 40.8 cm
- 3.1 kg
- Environmental Standards
- TCO Certified Displays 9
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 19"
- Panel Type
- TN
- Aspect Ratio
- 5:4
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM), ComfyView, Acer eColor technology
- Black
- 40.64 cm x 20.7 cm x 40.8 cm - with stand
- 3.1 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable
- Input Voltage
- 17.5 W
- Power Consumption SDR (On mode)
- 17.5 kWh/1000h
- Power Consumption (Typical)
- 15.8 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
- Dimensions & Weight Details
- Without stand - width: 40.64 cm - depth: 5.2 cm - height: 33.7 cm - weight: 2.7 kg , With stand - width: 40.64 cm - depth: 20.7 cm - height: 40.8 cm - weight: 3.1 kg
Sustainability Information
- TCO Certified
- Limited warranty - 3 years - carry-in
