Acer V196HQL 18.5" 1366 x 768 5ms VGA LED Black Monitor
Quicklinx: 8NTCWS00 Mfr#: UM.XV6EE.A03
Diagonal Size: 18.5in
Max Resolution: 1366 x 768
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
More than 50 in stock
£63.19 ex VAT
£75.82 inc VAT
Explore the angle that's perfect for you with this Professional series monitor, this monitor is wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitor. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Adaptable
    Explore the angle that's perfect for you with this Professional series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room.
  • Convincing
  • Prepared
    Collaborating with others is faster and more productive when you have plenty of ports available. Professional series monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA connectivity.
  • Green focus
    Professional series monitor is RoHS compliant and mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources.
Acer V196HQLAb - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
44.1 cm x 19.1 cm x 35.3 cm
2.72 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
18.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
2.72 kg
VGA
Mechanical
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
Power Supply
Internal
11.5 Watt
Power Consumption Stand by
0.45 Watt
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
Acer V196HQL 18.5 Bundle deal on Acer V196HQL 18.5" 1366 x 768 5ms VGA LED Black Monitor
£162.36
8NTC C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE In Stock £10.20
8NTC C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable In Stock £11.43
8NTC C2G VGA to Composite PC-TV Video Adapter In Stock £33.21
Response Time: 5ms
Speakers: None
Brand: Acer
Price Range Ex VAT: 50 - 100
