Ultra Short-throw Series projectors portray clear, large images even when positioned very close to the projection screen. This makes them ideal for use in education and business environments, as well as in small rooms.
Main Features
DLP technology.
Enables projecting 3D content via DLP Link Technology: Blu-Ray 3D supported.
One-touch "3D" button on remote control allows quick and easy access to the 3D functions.
Acer ColorBoost technology delivers vivid, life-like images.
High brightness and contrast ratio.
Versatile display modes enable optimum performance in any situation.
Lower power consumption and economy (ECO) mode extends lamp life.
Dynamic black / ExtremeEco functions help decrease lamp power consumption and further extend lamp life.
Acer EcoProjection Technology delivers Intelligent power management approach and physical efficiency improvement.
Manual focus/zoom projection lens.
2X digital zoom and pan move function.
- Acer U5220 - DLP projector - ultra short-throw - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3000 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Lens
- Ultra short-throw fixed lens
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 299 Watt
- 33.9 cm x 32.3 cm x 23.7 cm
- 5.5 kg
- 3-year warranty
- DLP projector
- 3D Capable
Projector
- Brightness
- 3000 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 13000:1 (dynamic)
- Image Size
- 152 cm - 305 cm
- Projection Distance
- 0.23 m - 0.8 m
- Throw Ratio
- 0.47:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 240 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
- Lens Aperture
- F/2.53
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -15 / +15
- Horizontal Keystone Correction
- -15 / +15
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x USB - 4 pin mini-USB Type B , 2 x Mobile High-Definition Link (MHL) / HDMI , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x network - RJ-45 (management) , 2 x audio line-in - mini-phone 3.5 mm , 1 x microphone input - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Nominal Voltage
- AC 120/230 V
- 299 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 33.9 cm
- 32.3 cm
- 23.7 cm
- 5.5 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 0 °C
- 40 °C
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 27 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £20.51 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £53.35 |
