Acer TravelMateP614 i7-10610U 8GB 512GB 14.0" Windows 10 Pro
Quicklinx: FXCKWS00 Mfr#: NX.VMQEK.009
  • Core i7
  • IEEE 802.11n
Work on the go and look great doing it with this sleek, ultra-portable laptop.
  • TravelMate P6
    Ultralight Performance for Hybrid Workstyles
  • Premium Portable Design
    Work on the go and look great doing it with this sleek, ultra-portable laptop. The stunning aluminum-magnesium alloy body is just 16.8mm thin and weighs as low as 1.0kg. The narrow-bezel 14" FHD+ IPS display with 100% sRGB coverage gives you vibrant, highly accurate colors and also a 16:10 aspect ratio that approaches the'golden ratio,' giving you even more screen and an extra boost to productivity.
  • 5G Connectivity Enabled
    Technology changes rapidly– and this laptop has incorporated plenty with Sub-6 5G connectivity. You'll maintain a consistent, high-speed wireless connection with eSim/uSim-enabled 5G technology. What's it all mean? Fast speeds, low latency, and the world at your fingertips.
  • Protecting Your Information
    The Acer PrivacyPanel is your first line of defense against prying eyes by keeping the information on your display private. The panel obscures viewing angles beyond 90° when activated, and can be turned off whenever you need to use the full 170° wide viewing angle of the display to share and collaborate.
  • Tough and Tested
    Durable and long-lasting, this laptop is MIL-STD 810H certified and stands up to all the rigors of business travel. The spill resistant keyboard and touchpad protects internal components from liquids, while the battery powers you through a day of meetings or offsite work. Fast charge technology also powers your device back up to 80% capacity in just an hour.
  • Industry-grade Security
    Ensure secure authentication and safeguard company data with the hardware-level Trusted Platform Module 2.0 and vPro remote management technology. The built-in Acer User Sensing technology allows for accurate detection of people based on range and movement, and keeps your data safe by locking the screen when you leave. When you return, quickly log back in with Windows Hello using the IR webcam or the fingerprint reader located on the power button.
  • Optimized for Conference Calls
    This laptop enhances conference calls with its dual upward speakers and a dual microphone array that picks up vocals from up to two meters away. AI-powered noise-reduction technology also dramatically improves clarity by minimizing background noise for crystal-clear online voice communication, while the MIPI webcam offers brighter and clearer images even in low-light situations. When the webcam is not in use, feel free to close the camera shutter for some extra privacy.
  • Ports Aplenty
    With dual USB 3.2 Gen 2 Type-C Thunderbolt 4 ports, you get blazingly fast data transfer rates up to 40Gpbs while supporting up to two 4K displays and battery charging. The full range of ports includes MicroSD and an NFC reader to easily share content or make mobile payments.
  • Ultimate Performance
    No job is too big or complex for the powerful processing power of an 11th Gen Intel Core i7 processor. Accomplish more and multitask with ease with up to 32 GB of rapid LPDDR4x memory and 1 TB of super-responsive M.2 PCIe Gen3 X4 NVMe SSD.
  • First-class Features
    Experience precise gesture control and swiping with the damage-resistant, ultra-responsive, and enlarged Corning Gorilla Glass Touchpad. The built-in DTS Audio and Smart Amplifier gives you higher-quality, distortion-free sounds and deeper bass while also protecting the speakers from damage as you pump up the volume.
Acer TravelMate P6 TMP614-51-G2-73G9 - 14" - Intel Core i7 - 10610U - vPro - 8 GB RAM - 512 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Platform Technology
Intel vPro Platform
Intel Core i7 (10th Gen) - 10610U / 1.8 GHz / 8 MB Cache
8 GB DDR4 (8 GB (soldered))
Storage
512 GB SSD
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics
Keyboard
Keyboard Backlight
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
4-cell - up to 20 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Mild black
32.5 cm x 23 cm x 1.66 cm
1.1 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (10th Gen) 10610U / 1.8 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Platform Technology
Intel vPro Platform
RAM
8 GB (8 GB (soldered))
Max RAM Supported
24 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
512 GB SSD M.2 2280 - Samsung
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
100% sRGB
Anti-glare, ComfyView, 25 ms response rate, Narrow Border Display
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - Full HD
Camera Features
IR camera, Windows Hello
Sound
Stereo speakers, four microphones
Audio Features
Output: Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 2230
Network Interface
Gigabit Ethernet
Wake-on-LAN (WOL)
4-cell Lithium Ion
60 Wh
Run Time
Up to 20 hours
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (DC-In combo) , USB 3.1 Gen 1 (with power off charging) , USB 3.1 Gen 1 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD)
Mild black
Security
MU-MIMO technology, HDCP Compliant
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
MIL-STD 810G
Localization
1.1 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
FXCK APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt In Stock £439.01
FXCK APC BACK-UPS BE650G2-UK 650VA 230V In Stock £107.41
FXCK APC BACK-UPS BE850G2-UK 850VA 230V USB In Stock £119.81
