The TravelMate Spin B3 notebooks are reliable devices designed around the needs of K-12 schoolchildren. They feature advanced processors, giving students all the power they need for classroom work, and comply with the MIL-STD 810G military standard, meaning that they're strong enough to survive the bumps and spills that are part of daily student life. A pressure-resistant top cover, shock-absorbent rubber bumper and reinforced corners all add to the durability of the devices. The notebooks can also get students through the entire school day on a single charge.
Efficient Performance
Get work and tasks done faster than other current on-the-market Window's laptops designed for education. The latest Intel processor combines low power consumption and high performance for a reliable classroom-based solution. -
Certified Durability
The Military Standard (MIL-STD 810H) certified impact-resistant design withstands up to 60kg of downward force in addition to increased resistance from daily wear and tear. The shock absorbent bumper and unique drainage design further protects components from moderate falls and amounts of liquid. -
Making Learning Fun
The convertible design of the laptop ensures that students are able to work together in a multitude of situations, easily adapting to either tablet, tent, or display modes. The optional additions of the dockable Wacom AES pen and the 5 Megapixel HDR world-facing camera further enable increased collaboration between students and flexibility in learning. -
The Cleaner and Tougher Touch Display
Acer's newest educational notebooks not only come equipped with Antimicrobial Corning Gorilla Glass, along the touchscreen, but also include internationally-certified antimicrobial (silver-ion) solutions which are implemented on the keyboard, touchpad, and palm-rest surface. -
Powering Through the Day
With an up to 12 hours of battery life in one charge, finish a days' worth of classes with battery to spare. The user-friendly port design keeps all your cables on the same side for greater accessibility and ease-of-use while the front-cover battery level indicator allows teachers to quickly and easily tell when a laptop is running out of charge. -
Uninterrupted Connectivity
A strong, consistent wireless signal is provided by Intel Wi-Fi 6 and the strategically placed wireless antenna with 2x2 MU-MIMO. When Wi-Fi is out of range, this laptop has optional 4G LTE– providing students with extra personal bandwidths to keep them connected and ensure they always have access to their data and apps in the cloud.
- Acer TravelMate Spin B3 TMB311RN-31-C0FM - 11.6" - Intel Celeron - N4120 - 4 GB RAM - 64 GB eMMC - UK
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Pro 64-bit National Academic
- Processor
- Intel Celeron N4120 / 1.1 GHz, up to 2.6 GHz / 4 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 64 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics 600
- Input Device
- Digitizer, digital pen
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell - up to 12 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Shale black
- 29.5 cm x 21.5 cm x 2.09 cm
- 1.49 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition National Academic
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
Storage
- Main Storage
- 64 GB eMMC - SanDisk
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Glare, CineCrystal, 25 ms response rate
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, two microphones
- High Definition Audio
Input
- Keyboard, digitizer, touchpad, digital pen
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB-C 3.1 , 2 x USB 3.0 , HDMI , Headphone/microphone combo jack , LAN
- Memory Card Reader
- Yes (SD Card)
- Shale black
- Security
- MU-MIMO technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, Acer Active Stylus
- MIL-STD 810G
- Localization
- 1.49 kg
Sustainability Information
- TCO Certified
