Acer TravelMate P658-M i7-6500U 8GB 256GB 15.6" Win 10 Pro 64-bit
Quicklinx: D9HQWS00 Mfr#: NX.VCYEK.008
  • Core i7
  • IEEE 802.11n
An extreme business tool, the TravelMate P6 series delivers superior performance plus high-level manageability and security features. This notebook is light and tough. This, plus an array of reliability features and long battery life, gives you peace of mind when on the go.
  • Superior productivity
    Increase efficiency with powerful processor. The HD anti-glare screen delivers great visuals, even in bright conditions and when viewed from wide angles. Conference calls are crisp in any environment, thanks to its webcam.
  • Tough and reliable
    TravelMate P6 features extra strength. In case the notebook is dropped, hard drive protection instantly terminates operations while Acer Disk Anti-Shock Protection (DASP) absorbs the shock.
  • Seamless connectivity
    Quickly connect anytime, anywhere. TravelMate P6 features USB 3.0, HDMI and VGA ports.
Acer TravelMate P658-M-75WD - 15.6" - Core i7 6500U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) 6500U / 2.5 GHz (3.1 GHz) / 4 MB Cache /
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader
38.1 cm x 25.45 cm x 2.24 cm
2.3 kg
Region: United Kingdom
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
20 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
256 GB SSD - (M.2 2280)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Anti-glare, ComfyView
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, two microphones
Audio Features
Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
3-cell lithium polymer
54 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
2 x USB 3.0 , HDMI , LAN , VGA , Dock , Headphone/microphone combo jack , USB-C Gen 2/Thunderbolt 3 , USB 3.0 (with power off charging)
Memory Card Reader
Yes (SD Card)
Case Material
Magnesium-aluminum alloy
Dockable
Security
Theft/Intrusion Protection
Power adapter
GS
Localization
2.3 kg
ENERGY STAR Certified
