The TravelMate P6 is a business laptop that's durable, light, and can last the whole day. It is powerful and secure to accommodate off-site meetings and constant business travel.
Built to last
Innovative use of materials means that the TravelMate P6 is light and durable - ideal for on-the-go professionals. -
Ultra quick data transfer
Ultra quick data transfer, external monitor connection, and battery charging with USB 3.1 Gen 2 Type-C. -
High-resolution results
With its IPS display, the TravelMate P6 delivers plenty of screen space that is visible from all angles. -
Steadfast reliability
G Sensor and Disk Anti-Shock Protection (DASP) safeguard your hard drive from all the knocks and drops of business travel. -
Advanced productivity
A powerful processor ensures you keep up with fast-paced work requirements.
- Acer TravelMate P658-G3-M-79GE - 15.6" - Intel Core i7 - 7500U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Keyboard
- UK
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 8 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 38.1 cm x 25.45 cm x 2.24 cm
- 2.09 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7500U / 2.7 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 24 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 - Micron
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Camera Features
- HDR (High Dynamic Range)
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Intel Wireless Display (WiDi)
- Technology
- 3-cell lithium polymer
- Capacity
- 4850 mAh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 ¦ HDMI ¦ LAN ¦ VGA ¦ Dock ¦ Headphone/microphone combo jack ¦ USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) ¦ USB 3.0 (with power off charging)
- Memory Card Reader
- Yes (SD Card)
- Black
- Case Material
- Polycarbonate, glass-fibre
- Dockable
- Security
- Disc Anti-Shock Protection System (DASP
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- GS
- Localization
- 2.09 kg
- Shipping Dimensions (WxDxH) / Weight
- 49.8 cm x 6.5 cm x 31 cm / 3.09 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
