An extreme business tool, the TravelMate P6 series delivers superior performance plus high-level manageability and security features. This notebook is light and tough. This, plus an array of reliability features and long battery life, gives you peace of mind when on the go.
Superior productivity
Increase efficiency with powerful processor. The HD anti-glare screen delivers great visuals, even in bright conditions and when viewed from wide angles. Conference calls are crisp in any environment, thanks to its webcam. -
Tough and reliable
TravelMate P6 features extra strength. In case the notebook is dropped, HDD FreeFall Protection instantly terminates operations while Acer Disk Anti-Shock Protection (DASP) absorbs the shock. -
Seamless connectivity
Quickly connect anytime, anywhere. TravelMate P6 features USB 3.0, HDMI and VGA ports.
- Acer TravelMate P658-M-52AM - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
- Storage
- 128 GB SSD
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Fingerprint reader
- Black
- 38.1 cm x 25.45 cm x 2.24 cm
- 2.3 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - TCO Certified Notebooks 8, ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 4 GB + 4 GB (soldered))
- Max RAM Supported
- 20 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Intel Wireless Display (WiDi)
- Technology
- 3-cell lithium polymer
- Capacity
- 4850 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , HDMI , LAN , VGA , Dock , Headphone/microphone combo jack , USB-C Gen 2 (supports Thunderbolt 3) , USB 3.0 (with power off charging)
- Memory Card Reader
- Yes (SD Card)
- Black
- Case Material
- Magnesium-aluminum alloy
- Dockable
- Security
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- GS
- Localization
- 2.3 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
