TravelMate P6
ULTRALIGHT PERFORMANCE FOR HYBRID WORKSTYLES -
Premium Portable Design
Work on the go and look great doing it with this sleek, ultra-portable laptop. The stunning aluminum-magnesium alloy body is just 16.8mm thin and weighs as low as 1.0kg. The narrow-bezel 14" FHD+ IPS display with 100% sRGB coverage gives you vibrant, highly accurate colors and also a 16:10 aspect ratio that approaches the'golden ratio,' giving you even more screen and an extra boost to productivity. -
Protecting Your Information
The Acer PrivacyPanel is your first line of defense against prying eyes by keeping the information on your display private. The panel obscures viewing angles beyond 90° when activated, and can be turned off whenever you need to use the full 170° wide viewing angle of the display to share and collaborate. -
Tough and Tested
Durable and long-lasting, this laptop is MIL-STD 810H certified and stands up to all the rigors of business travel. The spill resistant keyboard and touchpad protects internal components from liquids, while the battery powers you through a day of meetings or offsite work with up to 20 hours of use. Fast charge technology also powers your device back up to 80% capacity in just an hour.* -
Industry-grade Security
Ensure secure authentication and safeguard company data with the hardware-level Trusted Platform Module 2.0 and vPro remote management technology. The built-in Acer User Sensing technology allows for accurate detection of people based on range and movement, and keeps your data safe by locking the screen when you leave. When you return, quickly log back in with Windows Hello using the IR webcam or the fingerprint reader located on the power button. -
Optimized for Conference Calls
This laptop enhances conference calls with its dual upward speakers and a dual microphone array that picks up vocals from up to two meters away. AI-powered noise-reduction technology also dramatically improves clarity by minimizing background noise for crystal-clear online voice communication, while the MIPI webcam offers brighter and clearer images even in low-light situations. When the webcam is not in use, feel free to close the camera shutter for some extra privacy. -
Ports Aplenty
With dual USB 3.2 Gen 2 Type-C Thunderbolt 4 ports, you get blazingly fast data transfer rates up to 40Gpbs while supporting up to two 4K displays and battery charging. The full range of ports includes MicroSD and an NFC reader to easily share content or make mobile payments. -
Ultimate Performance
No job is too big or complex for the powerful processing power of an 11 th Gen Intel Core i7 processor. Accomplish more and multitask with ease with up to 32 GB of rapid LPDDR4x memory and 1 TB of super-responsive M.2 PCIe Gen3 X4 NVMe SSD. -
First-class Features
Experience precise gesture control and swiping with the damage-resistant, ultra-responsive, and enlarged Corning Gorilla Glass Touchpad. The built-in DTS Audio and Smart Amplifier gives you higher-quality, distortion-free sounds and deeper bass while also protecting the speakers from damage as you pump up the volume.
- Acer TravelMate P6 TMP614-51-G2-51EG - 14" - Intel Core i5 - 10210U - 8 GB RAM - 512 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (8 GB (soldered))
- Storage
- 512 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
- Battery
- 4-cell - up to 20 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- Mil black
- 32.5 cm x 23 cm x 1.66 cm
- 1.1 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (10th Gen) 10210U / 1.6 GHz
- Max Turbo Speed
- 4.2 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (8 GB (soldered))
- Max RAM Supported
- 24 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD M.2 2280 - Samsung
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 100% sRGB
- Anti-glare, ComfyView, 25 ms response rate, Narrow Border Display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - Full HD
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, two microphones
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
- Run Time
- Up to 20 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , USB 3.0 (with power off charging) , USB 3.0 , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Mil black
- Security
- MU-MIMO technology, HDCP Compliant
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- MIL-STD 810G
- Localization
- 1.1 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
