Acer TravelMate P459 Core i5-6200U 8GB 1TB 15.6" Win 10 Pro
Quicklinx: CM0JWS00 Mfr#: NX.VDVEK.005
  • Core i5
  • IEEE 802.11n
The TravelMate P4 has what it takes to enhance productivity. A backlit keyboard and optimized audio and video for web conferencing give you a further boost, functionally and ergonomically.
  • Designed to protect data
    To ensure data integrity, the primary storage has technology that detects sudden movement and immediately parks the drive heads to protect the internal mechanics. To guard against impact damage, the DASP system provides internal impact protection and external rubber cladding to further reduce damaging impact effects.
  • Configured for security
    Data security is another important priority where the P4 series excels. It ensures identity and credential security, and has a fingerprint reader with pre-boot authentication support to add further hardware-based security.
  • The performance to get more done
    A powerful processor delivers the performance to increase productivity for your business. Work the way you want and finish tasks quickly with power that keeps up with you. Multitask quickly and move effortlessly between applications, from email to a web browser to a video or spreadsheet and back again - all with the convenience of longer battery life.
Acer TravelMate P459-M-51PZ - 15.6" - Intel Core i5 - 6200U - 8 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
8 GB DDR4 (1 x 4 GB + 4 GB (soldered))
Storage
1 TB HDD / 5400 rpm
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel HD Graphics 520
Keyboard
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
4-cell - up to 8 hours
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader
37.95 cm x 25.4 cm x 2.21 cm
2.1 kg
Region: United Kingdom
Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Climate+
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 4 GB + 4 GB (soldered))
Max RAM Supported
20 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
1 TB HDD SATA 6Gb/s / 5400 rpm
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
HDCP, anti-glare, ComfyView
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Camera Features
HDR (High Dynamic Range)
Sound
Stereo speakers, microphone
Audio Features
Output: Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Numeric Keypad
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-LM
4-cell Lithium Ion
48 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
USB-C Gen 1 , USB 3.0 , 3 x USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2.1 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
