Take your workday productivity to new heights with the TravelMate P2. Combining processing power, portability and durability, and with a range of handy business features and connectivity options, it's everything a professional laptop should be.
Refined Elegance
Coming in an elegant and sturdy matte black chassis weighing just 1.6kg and less than 20mm thin, the TravelMate P2 combines style, functionality, and portability all into one device. The FHD IPS display boasts increased brightness, expanded contrast, and amazingly accurate colors with new, narrower bezels for a sleeker look and a more productive workday. -
Well Connected
Say goodbye to clunky video conferencing. With advanced Intel Wi-Fi 6 technology, you can now enjoy a smoother wireless experience with up to 3 times faster speeds than standard Wi-Fi 5 (802.11ac). And whenever Wi-Fi isn't available, Nano SIM and/or eSIM-enabled 4G LTE saves you the hassle of finding a local data plan. -
Robust Security
TPM 2.0 ensures secure authentication and safeguards company data, while the camera cover keeps the lens of the webcam blocked and your privacy protected when the camera is not in use. Additional security features, such as the fingerprint reader and Windows Hello, help with easy and secure access allowing you to unlock your device with just your fingertip or a quick glance at the camera. -
Inspired Productivity
Accelerate your multitasking thanks to the 10th Gen Intel Core i7 processor with vPro and NVIDIA GeForce MX230 for powerful computing and graphics performance. Work faster and accomplish more with up to 32GB of DDR4 memory and the configurable dual-drive system featuring a 1TB high-capacity HDD and a super-responsive 512GB 4–lane PCIe SSD. -
Designed to Last
Power your way through work and meetings. The TravelMate P2 easily lasts through a day of work with up to 13 hours of battery life, letting you work uninterrupted without needing to recharge. Further, the Military Standard tested and impact-resistant chassis stands up to daily wear and tear, ensuring it can survive shocks, drops, rain and more. -
Bring More to the Table
The TravelMate P2 boasts a full range of ports such as VGA, HDMI, and USB Type-C, which can easily expand the amount of available ports through the Acer USB Type-C Dock. With the dock connected, you'll be able to connect 4K displays, charge multiple devices, and connect all of your workspace peripherals as you see fit. -
Reliable learning companion
Striking the perfect balance between perfomance& efficency, TravelMate series notebooks are reliable learning companions powerful enough to handle most workloads. -
The performance you need
Based on the latest Intel Core processors and equipped with up to 16GB of DDR3L memory, TravelMate P2 notebooks can effortlessly handle common school tasks. -
Intuitive usability
Precision touchpad fully supports the new Windows 10 features. Students can exploit Face Login recognition technology to quickly and safely access the OS and websites, and forget about passwords. -
Easy to manage and secure
TravelMate P2 notebooks come with a set of handy manageability and security tools so the devices are easy to deploy and handle even without dedicated IT staff.
- Acer TravelMate P2 TMP214-52-39XV - 14" - Intel Core i3 10110U - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i3 (10th Gen) 10110U / 2.1 GHz (4.1 GHz) / 4 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
- Battery
- 4-cell - up to 11 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Black
- 32.89 cm x 23.775 cm x 1.99 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- TCO Certified Notebooks 9, ENERGY STAR Qualified
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 - Kingston
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView, 8 ms response rate, Narrow Border Display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Sound
- Stereo speakers, two microphones
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- HDMI , VGA , USB 3.0 (with power off charging) , 2 x USB 3.0 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Black
- Security
- HDCP Compliant
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter, HDD kit
- MIL-STD 810G
- Localization
- 1.6 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
