Acer TravelMate P2 Intel Core i5-10110U 8GB 128GB 14" Windows 10 Home 64-bit
Quicklinx: FTQQWS00 Mfr#: NX.VLFEK.00A
  • Core i5
  • IEEE 802.11n
Take your workday productivity to new heights with the TravelMate P2. Combining processing power, portability and durability, and with a range of handy business features and connectivity options, it's everything a professional laptop should be.
  • Refined Elegance
    Coming in an elegant and sturdy matte black chassis weighing just 1.6kg and less than 20mm thin, the TravelMate P2 combines style, functionality, and portability all into one device. The FHD IPS display boasts increased brightness, expanded contrast, and amazingly accurate colors with new, narrower bezels for a sleeker look and a more productive workday.
  • Well Connected
    Say goodbye to clunky video conferencing. With advanced Intel Wi-Fi 6 (802.11ax) technology, you can now enjoy a smoother wireless experience with up to 3 times faster speeds than standard Wi-Fi 5 (802.11ac). And whenever Wi-Fi isn't available, Nano SIM and eSIM-enabled 4G LTE saves you the hassle of finding a local data plan.
  • Robust Security
    TPM 2.0 ensures secure authentication and safeguards company data, while the camera cover keeps the lens of the webcam blocked and your privacy protected when the camera is not in use. Additional security features, such as the fingerprint reader and Windows Hello, help with easy and secure access allowing you to unlock your device with just your fingertip or a quick glance at the camera.
  • Inspired Productivity
    Accelerate your multitasking thanks to the 11th Gen Intel Core i7 processor and NVIDIA GeForce MX330 for powerful computing and graphics performance. Work faster and accomplish even more with up to 32GB of rapid DDR4 memory and the configurable dual-drive system featuring a 1TB high-capacity HDD and a super-responsive 1TB 4–lane PCIe SSD.
  • Designed to Last
    Power your way through work and meetings. The TravelMate P2 easily lasts through a day of work with up to 13 hours of battery life, letting you work uninterrupted without needing to recharge. Further, the Military Standard tested and impact-resistant chassis stands up to daily wear and tear, ensuring it can survive shocks, drops, rain and more.
  • Bring More to the Table
    The TravelMate P2 boasts a full range of ports such as VGA, HDMI, USB Type-C, and the latest Thunderbolt 4, with additional port expansion a possibility thanks to the optional Acer USB Type-C Dock,. With the dock connected, you'll be able to connect 4K displays, charge multiple devices, and connect all of your workspace peripherals as you see fit.
Acer TravelMate P2 TMP214-52-56E9 - 14" - Intel Core i5 - 10210U - 8 GB RAM - 128 GB SSD - UK
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
128 GB SSD
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel UHD Graphics
Keyboard
Integrated Webcam
Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
4-cell - up to 11 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
32.89 cm x 23.775 cm x 1.99 cm
1.6 kg
Region: United Kingdom
Environmental Standards
TCO Certified Notebooks 9, ENERGY STAR Qualified
Limited warranty - 1 year , International travellers warranty - 1 year
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
128 GB SSD M.2 2280 - Kingston
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, ComfyView, 10 ms response rate, Narrow Border Display
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, two microphones
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201 - M.2 2230
Network Interface
Gigabit Ethernet
Wake-on-LAN (WOL)
4-cell Lithium Ion
48 Wh
Run Time
Up to 11 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
HDMI , VGA , USB 3.0 (with power off charging) , 2 x USB 3.0 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Security
HDCP Compliant
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, HDD kit
MIL-STD 810G
Localization
1.6 kg
Sustainability Information
TCO Certified
- TCO Certified Notebooks 9
ENERGY STAR Certified
