The TravelMate P2 series meets various business needs. Clad in a refined textile finish that both looks and feels great, these notebooks pack fast processors and discrete graphics to keep you productive.
Efficient productivity
Support for up to three displays helps to speed project work, making it easier to switch between several open documents and apps at the same time. As a result, multi-tasking and productivity are vastly improved.
In addition, thanks to the Acer ComfyView™ anti-glare display that reduces reflection, you can enjoy crisp images with vivid colours and optimal contrast rate even when working outdoors. To use the notebook for an extended period of time with less eye strain you can turn on Acer BluelightShield™ that lowers blue light emission by up to 54%.
Attractive design
When it comes to design, TravelMate P2 series has an edge: simplicity embellished with a unique finish. The sophisticated textile pattern on the top cover and underside not only helps to prevent scratches, but it makes the notebook more comfortable to hold and feels good to the touch.
The undercut design on the front and rear edge emphasizes the slim and light look and improves usability, making the cover easy to open with just one hand.
Integrated security and manageability
TravelMate P2 series allows users to have everything under control with useful management and security tools. Acer ControlCenter includes several functions that allow thoroughly monitoring the system status, from computer health to software deployment, from policies checking to updates. Acer Office Manager (AOM) is easy to use and helps small businesses to deploy security policies, monitor IT assets, and schedule maintenance tasks even without dedicated staff.
Acer ProShield is a security portal that allows users to manage their credentials and create extra layers of protection to keep their devices secure.
To store important data and documents almost forever, the optical drive is M-DISC™ ready. Compared to hard drive, DVD and flash drive, M-DISC ensures a much longer storage life, making it perfect for archiving critical company data.
Effortless communications
A range of connectivity options, including Bluetooth 4.0, keeps users connected anywhere their business takes them. In addition, wireless LAN technology supports AC1 for fast Internet speed, even where Wi-Fi connectivity is erratic.
TravelMate P2 Series delivers the high audio and visual standards of Skype for Business Certification. The webcam with HDR captures and generates clear images even when light is weak; combined with a built-in digital microphone and stereo speakers it ensures flawless web-conferencing, so you can talk with contacts as if they were in the room and make your business even more successful.
Intuitive usability
TravelMate P2 notebooks are engineered to enable smoothinteraction. Users can work faster and smoother thanks tothe Precision Touchpad, that accurately recognises fingertipmovements and fully supports the new Windows 10 features: Cortana, Multitasking and Action Center.
Through Contact Pickup, users can share their business contact information more easily. Via QR code, the tool saves contact details on other people’s smartphones in a flash. Users can also exploit Face Login recognition technology to quickly and safely access OS and websites, and forget about passwords.
Fabric-inspired pattern
Textured fabric-inspired patterns give the notebooks an audacious, yet minimalistic look and feel.
Brushed metal surface
The hairline-brushed inner metal surface offers a visually and tactilely pleasing platform for typing and navigating.
Diamond-cut edges
Beveled diamond-cut edges add an understated, yet bold sense of depth to the overall design of the notebook.
Comprehensive manageability
Acer ControlCenter places crucial functions and utilities into a single, fast-access panel.
Multiple display support
If your TravelMate P2's spacious Full HD screen isn't enough, expand your desktop to 2 external displays for optimized multitasking.
Reliable security
With Trusted Platform Module and Acer ProShield portal, keep your data under your control.
Fingerprint reader
An embedded fingerprint reader works with Windows Hello to let you sign into your PC securely with just one touch.
Tactile textile
The P2 series comes with a textile pattern embossed on the outer covers. This lends a professional refined look and feel to the line that adds distinction to functionality. There's also a practical benefit, as the pattern makes it a bit easier to keep a firm grip, while also resisting scratches. -
Intuitive and efficient
The TravelMate P2 is packed with features that make it easier to do business. Work faster with smoother gestures on the large, precise touchpad.
- Acer TravelMate P238-M-58QJ - 13.3" - Intel Core i5 - 6200U - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 5400 rpm
- Display
- 13.3" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 4-cell
- Black
- 32.7 cm x 22.8 cm x 1.965 cm
- 1.6 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - TCO Certified Notebooks 9, ENERGY STAR Qualified EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA / 5400 rpm
Display
- 13.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- HDCP, anti-glare, ComfyView, Mercury free
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: Acer TrueHarmony technology
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell lithium polymer
- Capacity
- 3270 mAh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , LAN , 2 x USB 2.0 , USB 3.0 (with power off charging) , USB-C Gen 1 , Headphone output
- Memory Card Reader
- Yes (SD Card)
- Black
- Administrator password, system password, hard drive password, wake on LAN, NIL Technology (Nanoimprint Lithography)
- Included Accessories
- Power adapter
- ACPI 5.0
- Localization
- 1.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
