Travelmate b117-m intel everyday productivity on the gothe travelmate b series features the unique flowcurve design that makes it stand out in a crowd of traditional laptops. it doesn't need a fan - so it's whisper-quiet and runs cool. the travelmate b is slender and light- for portable computing with all the windows tools for great productivity.unique - smart designthe travelmate b series stands out in a crowd because of its unique flowcurve design. the large precision touchpad is optimized for accuracy and sensitivity - giving you a touch-gesture experience that's as smooth as on a touchscreen. an aluminum top cover with a fibonacci dot pattern design rounds out this laptop's premium look.productivity on the goit's thin and light - so you can slip it into your bag and forget about it. combine that with impressive processing and huge storage - you get a great tool for staying productive wherever you roam. it doesn't require a cooling fan - so it runs cool and whisper-quiet.better for your eyesacer bluelightshield minimizes eye-strain from prolonged screen viewing by filtering out blue light. plus - acer comfyview reduces annoying ambient reflections - which comes in handy when you're working outdoors
Great for collaborating
These notebooks facilitate group work with light form factors and screens that open 180° for easy collaboration. Also with wireless antennas and MIMO modules, wireless connectivity is fast and smooth. -
Tough & sturdy
They are protected from bumps and drops with a robust rubber strip, while their keyboards are resistant to accidental spills. What's more, their hinges have been designed to withstand thousands of lid openings. -
Better navigation
Students will enjoy smoother swiping, scrolling, and zooming with advanced touchpads. The chiclet keyboards offer great travel distance and solid tactile feedback for a reliable and responsive typing experience.
- Acer TravelMate B117-M-P9MZ - 11.6" - Intel Pentium - N3710 - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Pentium N3710 / 1.6 GHz, up to 2.56 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 405
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 4-cell - up to 12 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Black
- 29.1 cm x 21.1 cm x 2.23 cm
- 1.45 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.56 GHz
- Number of Cores
- Quad-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB SSD
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Camera Features
- HDR (High Dynamic Range), 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-gesture touch pad, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - M.2 Card
- Intel Wireless Display (WiDi)
- Technology
- 4-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- USB 2.0 , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
- Black
- Security
- Administrator password, system password, hard drive password
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- Localization
- 1.45 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
