Do more than just view an image. Touch it. Control it. Interact with it using Acer's advanced Touch series monitors. Multi-touch and great digital connectivity are brought together with style to provide the ultimate touch experience. Plus, an ergonomic design lets you navigate in complete comfort.
- Acer T272HUL - LED monitor - 27"
- LED-backlit LCD monitor - 27" - touchscreen
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI
- Speakers
- Integrated
- Voltage
- AC 120/230 V
- Black
- 66 cm x 5 cm x 49.3 cm
- 7.2 kg
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Black
- 66 cm x 5 cm x 49.3 cm - with stand
- 7.2 kg
Audio
- Speakers - integrated
Input
- Touchscreen
- DVI , HDMI , USB
- Cables Included
- 1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
- MPR II
- Input Voltage
- AC 120/230 V
- 30 W
- Power Consumption (Typical)
- 29.94 Watt
- Power Consumption Stand by
- 460 mW
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 66 cm - depth: 3.8 cm - height: 47 cm - weight: 6.75 kg , With stand - width: 66 cm - depth: 5 cm - height: 49.3 cm - weight: 7.2 kg
- Limited warranty - 2 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
