Acer Switch One 10 SW1-011 AtomTM x5-Z8300 2GB 32GB 10.1" Win 10
Quicklinx: CJ45WS00 Mfr#: NT.LCSEK.001
  • IEEE 802.11n
A mode for every mood
With four modes, the Switch One 10 has a configuration to suit whatever mood you’re in.
Four modes
Whether you’re in the mood for work or play, the Switch One 10 has a mode for it. Choose from four modes – Notebook mode for typing, Pad mode for using touch, and Tent and Display modes for entertainment.
Snap on, snap off
A latch-less magnetic hinge design makes switching between modes easy. It doesn’t have awkward mechanical connectors, so you can snap the tablet and keyboard together, or pull them apart, easily.
See it better
With a 10.1" HD (1280 x 800) display, everything will look crisp and clear. Plus with IPS technology, you won’t lose any details or color saturation when viewing the screen from wide angles.
Feel the metal
The Switch One 10 features a design that’s sophisticated, sleek and simple. Its brushed-metal cover gives it a unique and refined look that isn’t overpowering, and also has a nice tactile feel to it.
  • Snap on, snap off
    A magnetic hinge design makes switching between modes easy. It doesn't have awkward mechanical connectors, so you can snap the tablet and keyboard together, or pull them apart, easily.
  • See it better
    With a crisp display, everything will look clear. Plus with IPS technology, you won't lose any details or color saturation when viewing the screen from wide angles.
  • Feel the metal
    The Switch One 10 features a design that's sophisticated, sleek and simple. Its brushed-metal cover gives it a unique and refined look that isn't overpowering, and also has a nice tactile feel to it.
Acer Switch One 10 SW1-011-177D - 10.1" - Intel Atom x5 - Z8350 - 2 GB RAM - 32 GB eMMC - UK
Tablet - with keyboard dock
Operating System
Win 10 Home 32-bit
Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache
2 GB DDR3L (provided memory is soldered)
Storage
32 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics
Input Device
Touchpad, detachable keyboard
Keyboard
Integrated Webcam
Bluetooth, 802.11b/g/n
2-cell - up to 10 hours
G-sensor
Dockable
Steel grey, iron
Dimensions (WxDxH) - tablet
25.9 cm x 18.05 cm x 0.965 cm
680 g
Region: United Kingdom
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Home 32-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
1.92 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
2 GB (provided memory is soldered)
DDR3L SDRAM
Storage
Main Storage
32 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Image Brightness
300 cd/m²
HDCP, glare, CineCrystal
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
Resolution
2 Megapixel (rear), 2 Megapixel (front)
Camera Features
720p HD movie recording
Sound
Stereo speakers, microphone
Input
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
Realtek RTL8723BS
2-cell lithium polymer
31.2 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
15 Watt, 5 V, 3 A
Connections & Expansion
Interfaces Details
Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
Memory Card Reader
Yes (microSD)
Steel grey, iron
Case Material
Anodised aluminium
Integrated Options
G-sensor
Dockable
Volume control
Power adapter
Localization
680 g
Dimensions (WxDxH) / Weight Details
25.9 cm x 18.05 cm x 0.965 cm / 680 g - tablet , 25.9 cm x 19.26 cm x 2.065 cm / 1.26 kg - tablet with keyboard
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
