Acer Switch 10E Atom Z3735F 64GB Windows 10 White
Quicklinx: BTPWWS00 Mfr#: NT.MX1EK.004
  • Atom
  • Bluetooth 4.0
  • IEEE 802.11n
Versatile, practical and powerful, the Acer Aspire Switch 10 E provides the perfect blend of multimedia fun and serious productivity.
The shape-shifting Aspire Switch 10 E has a detachable keyboard which can be attached and removed with a simple push or pull. It can be switched between four different modes - notebook, tablet, tent and display - depending on which is most convenient for your needs.
It's equipped with a 1.33GHz Intel Atom processor for enhanced graphics and gaming performance, 2GB RAM and a generous 64GB of hard drive storage space. Its two-cell battery provides up to 12 hours of power, so you'll have more than enough time to get that essential work done while you're on the move.
This Acer 10-inch tablet also comes in a range of cool colours, so you can choose the one that suits your personal style. It also features an HD screen with IPS technology, so you're guaranteed a great view whichever angle you're looking at it from.
  • Fluidly elegant
    The Aspire Switch 10 knows design doesn't only live in a static image. Design lives in use. It is the feeling of the metal under fingers, a smooth release, a conveniently slim profile. Acer Snap Hinge design is flipping, folding, docking, detaching and all of the activities that ensue.
  • Delightfully productive
    The Aspire Switch 10's processor and Microsoft InstantGo means a smooth, fast experience and less time wasted.
  • Stunningly vibrant
    The Aspire Switch 10 makes visuals enjoyable in any situation. From a game between airport gates to a TV show caught between classes to an interactive children's book before goodnight, the Zero Air Gap (direct bonding) and IPS technology offer a stunning display for one or many.
  • Immensely adaptable
    Use the Aspire Switch 10 as a portable tablet, type with its keyboard for productivity, pivot its screen to share a presentation with others, or flip it to watch a movie when space is limited. Switch between laptop, tablet, display screen and tent modes to enhance your work and play.
  • Extraordinarily bright
    Whether you're an indoors person, an outdoors person, or a bit of both, the Aspire Switch 10 is designed to be used everywhere you go. Its LumiFlex display technology provides optimized color control that lets you watch videos and share photos even under the sun.
Acer Aspire Switch 10 E SW3-013-1041 - 10.1" - Intel Atom - Z3735F - 2 GB RAM - 64 GB eMMC
Tablet - with keyboard dock
Operating System
Win 10 Home 32-bit
Intel Atom Z3735F / 1.33 GHz, up to 1.83 GHz / 2 MB Cache
2 GB DDR3L (provided memory is soldered)
Storage
64 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics
Input Device
Touchpad, detachable keyboard
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
2-cell - up to 12 hours
Ambient light sensor, G-sensor
Dockable
Black, white
Dimensions (WxDxH) - tablet
26.2 cm x 18 cm x 1.095 cm
630 g
Region: United Kingdom
Environmental Standards
Operating System
Windows 10 Home 32-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
1.83 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
Intel Burst Technology
RAM
2 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
64 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
350 cd/m²
HDCP, glare, CineCrystal, Mercury free
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1600 x 1200 (rear), 1600 x 1200 (front)
Resolution
2 Megapixel (rear), 2 Megapixel (front)
Camera Features
720p HD movie recording
Sound
Stereo speakers, microphone
Input
Multi-gesture touch pad, Acer FineTip keyboard
Communications
Wireless
Wireless Controller
M.2 Card
2-cell lithium polymer
30 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
10 Watt, 5.35 V, 2 A
Connections & Expansion
Interfaces Details
Micro-USB 2.0 , Micro-HDMI , Headphone/microphone combo jack , Dock , USB 2.0 (on keyboard dock)
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Black, white
Integrated Options
Dockable
Volume control
Power adapter
ACPI 5.0
Localization
630 g
Dimensions (WxDxH) / Weight Details
26.2 cm x 18 cm x 1.095 cm / 630 g - tablet , 26.2 cm x 18 cm x 2.285 cm / 1.2 kg - tablet with keyboard
Sustainability Information
TCO Certified
