Acer Swift 5 Pro Core i5-8250U 8GB 256GB SSD 14" Windows 10 Pro
Quicklinx: DRHNWS00 Mfr#: NX.H0DEK.001
Display Size: 14in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£861.90 ex VAT
£1,034.28 inc VAT
Size, shape, and style: the triple "s" combo that makes the Swift 5 Pro the champion of portable computing. Knock out your daily computing needs with powerful tech features that keep you active and on the move.
  • Tough, Light and Thin
    The ultra-light magnesium-lithium and magnesium-aluminum metal chassis, at just 990g it is the lightest 14" notebook with a powerful graphics card in its class and it's just 14.95mm thin.
  • 990 g
  • Mg-Al& Mg-Li
    Chassis
  • Clearer, Brighter Vision
    With its narrow bezels on three sides, and an impressive screen-to-body ratio, you get more on the 14" FHD IPS touchscreen.
  • 86.4%
    Screen-to-Body Ratio
  • All-day Power
    When you're on the move, you don't want to worry about your laptop not performing as you'd expect. The Swift 5 gives you all the power you need for a full day's work and entertainment.
  • Next Gen CPU
    10th Gen Intel Core processors deliver approx. 2.5x-3x accelerated AI performance, up to 2x Graphics performance and nearly 3x faster wireless speeds.
  • Supercharged Graphics
    The NVIDIA GeForce MX250 provides up to 3.5X faster performance over integrated graphics for photo and video-editing applications, as well as faster, smoother gaming.
  • Long Battery Life
    Spending all-day on the move requires a large battery, and at 56Wh it's capable of lasting for up to 12.5 hours. In cases of emergency it can also be fast charged to provide 4.5 hours use from 30 minutes charge.
  • Connectivity
    With a full range of connectivity options including full function USB-C, Thunderbolt 3 the Swift 5 is capable of quickly connecting too many state-of-the-art devices. And, to be sure you can connect to legacy devices it also comes with USB 3.1 Gen 2 and a display port.
  • Dual Band Wi-Fi
    The Wi-Fi connection is provided by dual-band Intel Wi-Fi 6 (GIG+) (802.11ax) which provides 1, 700 Mbps download speeds, 75% lower latency and Improved security.
  • MU-MIMO
    MU-MIMO can handle multiple wireless devices at once with faster speeds and is 3 X faster than single-user MIMO.
  • USB-C
    A single connector can be used for ultra-quick data transfer, video streaming, and battery charging/power. USB 3.1 is 10 times faster than USB 2.0.
  • Storage
    Modern laptop users demand plenty of storage for audio and video files and plenty of memory to play them efficiently. This Swift 5 comes with a maximum of 512 GB PCIe Gen 3x4 SSD, and up to 16GB LPDDR4 RAM.
  • Smart Access
    The Swift 5 can be accessed even faster and more securely without having to use a password. Thanks to Cortana it can also be used as smart assistant to answer a wide range of questions.
  • Embedded Fingerprint Reader
    An embedded fingerprint reader is a quick and secure way for Windows Hello to verify your identity without a password.
  • Wake On Voice (WoV)
    Activate and query Windows 10 when the screen is off. Interact with Cortana when in Modern Standby mode.
  • Cortana
    Microsoft's Intelligent Personal Digital Assistant, helps you stay on time for tasks and meeting schedules and syncs with multiple devices.
Acer Swift 5 Pro Series SF514-52TP - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
14" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell - up to 8 hours
Security
Fingerprint reader
Charcoal blue
32.9 cm x 22.8 cm x 1.49 cm
970 g
Region: United Kingdom
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Storage
Main Storage
256 GB SSD M.2 2280 - Micron
Display
14" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Glare, CineCrystal, 25 ms response rate
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Sound
Stereo speakers, microphone
Dolby Audio Premium
Audio Features
Acer TrueHarmony technology
Input
Keyboard, touchpad
Keyboard Backlight
Keyboard Layout
Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - M.2 Card
Intel Wireless Display (WiDi)
2-cell lithium polymer
36 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
HDMI , USB 3.0 , USB-C 3.1 Gen 1/DisplayPort , Headphone/microphone combo jack , USB 3.0 (with power off charging)
Charcoal blue
Security
Fingerprint reader
Power adapter
Localization
970 g
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Type: Laptop
Brand: Acer
Price Range Ex VAT: 750 - 1000
