The elegantly thin design ensures that the monitor looks great and gives more space to its screen. With its wide viewing angles and IPS technology you can share the images with those around you.
- Acer SA240Y - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 15.9 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Black
- 53.98 cm x 21.18 cm x 40.52 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class E
- 28 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Acer VisionCare, 6-bit gamma, Wide Viewing Angle, Acer BluelightShield technology, Ultra Thin
- Black
- 53.98 cm x 21.18 cm x 40.52 cm - with stand
- HDMI , DVI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- 15.9 W
- Power Consumption SDR (On mode)
- 15.9 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.4 Watt
- Dimensions & Weight Details
- With stand - width: 53.98 cm - depth: 21.18 cm - height: 40.52 cm , Without stand - width: 53.98 cm - depth: 3.41 cm - height: 32.3 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
