Acer S1283Hne DLP 3D 3100 Lumens Projector
Quicklinx: BCW4WS00 Mfr#: MR.JK111.002
Acer’s Education series projectors portray clear, large images from either a distance, or when positioned conveniently close to the projection screen. This makes them ideal for use in education facilities or any smaller space. Their high resolution makes for clear and detailed big screen images, while color enhancement features deliver vivid hues.
  • From near or far
    The Education series projectors are great for both small rooms and classrooms. Positioning the projector close to the screen lets you easily point out details without casting shadows or being dazzled by the bright projector beam. For larger or more conventional rooms, you’ll appreciate their powerful ability to project a bright image from a distance.
  • Rich visuals
    Education series projectors deliver XGA resolution to display video, enabling them to display fine detail and small print clearly. Bright projector lamps and high contrast ratios produce vivid images, while Acer ColorBoost and Acer ColorSafe technologies deliver improved color performance and fidelity, with impressive results.
  • Conveniently flexible
    Acer's top-loading design enables quick and easy lamp replacement. These projectors also have a wide range of ports that can connect to all sorts of other equipment.
  • Eco-smart
    Education series projectors have Acer EcoProjection technology and use very low wattage in standby mode, which lowers their power consumption, lengthens lamp lifespan to many hours, and reduces noise levels. These projectors not only reduce energy consumption and lamp replacement costs, they also have less environmental impact.
Acer S1283Hne - DLP projector - ultra short-throw - portable - 3D - LAN
DLP projector
3D Capable
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3100 lumens
Contrast Ratio
13000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Lens
Ultra short-throw lens
Bulb type
P-VIP 210 Watt
Bulb life cycle
Up to 4000 hours - normal mode , Up to 8000 hours - economic mode
Video Input
RGB, S-Video, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - internal
AC 120/230 V
290 Watt
31.4 cm x 22.3 cm x 9.3 cm
2.8 kg
Pricing Type
Academic
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
3100 lumens
Brightness (Reduced)
2480 lumens
Contrast Ratio
13000:1 (dynamic)
Image Size
81 cm - 762 cm
Projection Distance
0.4 m - 3.8 m
Throw Ratio
0.617:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
P-VIP 210 Watt
Bulb life cycle
ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 24p True Cinema, Digital Zoom, Acer ColorSafe II Technology, MHL compliance, Quick-Start
Lens
Focus Type
Manual
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Carrying case, wireless remote control
1 x VGA cable
Pricing Type
Academic
AC 120/230 V
290 Watt
Power Consumption Stand by
0.5 Watt
31.4 cm
22.3 cm
9.3 cm
2.8 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
31 dBA
28 dBA
BCW4 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
