These displays deliver high resolution, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source. RT0 monitors feature very thin panels. Its ZeroFrame design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand. RT0 displays use Flicker-less technology to reduce eye-strain-causing screen flickering. Blue Light Filter technology lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView technology reduces the light reflected off the screen.
                Quality visualsThese displays deliver high resolution, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source.
                Slender body, sleek standRT0 monitors feature very thin panels. Its ZeroFrame design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand.
                Good for your eyesRT0 displays use Flicker-less technology to reduce eye-strain-causing screen flickering. Blue Light Filter technology lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView technology reduces the light reflected off the screen.
- Acer RT280K - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class B
- Energy Consumption per Year
- 64 kWh
- Power Consumption (On mode)
- 44 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- HDMI, DVI, DisplayPort
- Tilt
- Black
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 64 kWh
- Diagonal Size
- 28"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Black
- DVI , DisplayPort , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA interface support
- Cables Included
- 1 x DVI cable , 1 x DisplayPort cable
- MPR II
- 44 W
- Power Consumption (Typical)
- 41.5 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
|  | StarTech.com Dual Monitor Mount - Stackable | In Stock | £212.26 |
|  | StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.22 |
|  | StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.15 |
|  | StarTech.com Monitor Desk Mount - Steel | In Stock | £43.93 |
