The Acer RT240Y monitor has an ultra-thin enclosure and an elegant T-shaped metal stand, making it ideal for everyday computing in any space. The stylish Zero Frame design maximizes the view and minimizes visual clutter with a bezel so thin you barely notice it, providing a seamless viewing experience for multi-monitor setups. Combining Acer Flicker-Less and Blue Light Filter technologies with adjustable tilt, the monitor is easy on the eyes, providing a comfortable viewing experience.
Quality visuals
These displays deliver 1920x1080 Full HD resolution enhanced by IPS technology, for vivid images that look clear from any angle. You also get multiple display connectors to make it easy to connect any video source. -
Slender body, sleek stand
RT0 monitors feature very thin panels. Its "ZeroFrame" design means the bezels around the sides of the screen are also very thin, to minimize visual clutter. The slender screen is perfectly balanced by the sleek T-shaped stand. -
Good for your eyes
RT0 displays use Flicker-less tech to reduce eye-strain-causing screen flickering. Blue Light Filter tech lets you filter out strain-causing blue light when you have to work long hours, and Acer ComfyView tech reduces the light reflected off the screen. -
No screen tearing
Say "goodbye" to stuttering and tearing. FreeSync and Adaptive-Sync technologies match the refresh rate of your monitor with your graphics card to provide the smoothest gaming experience.
- Acer RT240Ybmid - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class D
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.98 cm x 19.62 cm x 40.53 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class D
- 32 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Mercury free, Flicker-Less technology, Blue Light Filter technology, 6-bit gamma, 72% NTSC colour gamut
- Black
- 53.98 cm x 19.62 cm x 40.53 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI (HDCP) , VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- 22 W
- Power Consumption SDR (On mode)
- 13 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.4 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 53.98 cm - depth: 19.62 cm - height: 40.53 cm , Without stand - width: 53.98 cm - depth: 3.41 cm - height: 32.3 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
