Acer Revo M1-601 Pentium-3700D 2GB 32GB Windows 10
Quicklinx: CHY2WS00 Mfr#: DT.B2AEK.003
  • Pentium
  • IEEE 802.11n
The new Revo Build Series (M1-601) Mini PC takes a modular approach to allow consumers to customize their computer without opening up the chassis. "Blocks" with different features can be easily stacked on top of the base unit, which makes adding functionality as easy as playing with toy blocks. The "Blocks" are connected through pogo pins with magnetic alignment so that there's no hassle with wires when swapping out modules. The Blocks can also work independently or with other PCs. The Revo Build M1-601 desktop is packaged in a tiny 1 liter chassis with a 125 x 125 mm footprint that takes up minimal space and can be placed almost anywhere.
Acer Revo Build M1-601_VN3700D - mini PC - Pentium N3700 1.6 GHz - 2 GB - SSD 32 GB
Personal computer - mini PC
Region: United Kingdom
Intel Pentium N3700 / 1.6 GHz (, up to 2.4 GHz, (Quad-Core)
Processor Main Features
Intel Burst Technology
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
2 GB DDR3L SDRAM
Hard Drive
SSD 32 GB - eMMC
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics
GigE, Bluetooth, 802.11a, 802.11b/g/n, Wi-Fi 5
OS Provided
Windows 10 Home 64-bit Edition
Black, orange strip
13.5 cm x 13.5 cm x 5.6 cm
1 kg
Personal computer
Product Form Factor
Mini PC
Black, orange strip
Processor / Chipset
CPU
Intel Pentium N3700
Clock Speed
1.6 GHz
Max Turbo Speed
2.4 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
2 GB
DDR3L SDRAM
Effective Memory Speed
1600 MHz
SO-DIMM 204-pin
Configuration Features
1 x 2 GB
Hard Drive
SSD - eMMC
1 x 32 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI, DisplayPort
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Slots
1 (total) / 0 (free) x CPU , SO-DIMM 204-pin
3 x USB 3.0 , 1 x LAN , 1 x headphones/microphone , 1 x HDMI , 1 x DisplayPort
Wireless antenna
CB, FCC, RoHS
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
13.5 cm
13.5 cm
5.6 cm
1 kg
