Acer R271bmid 27" 1920x1080 4ms VGA DVI HDMI Monitor
Quicklinx: CP84WS00 Mfr#: UM.HR1EE.001
Select:
  • 27"
  • Slim and trim
    R1 displays have an ultra-thin enclosure with most of the display being only 6.6 mm thick, thinner than many smartphones. In addition, the"ZeroFrame" design maximises the view and minimises visual clutter with a bezel so thin that you barely notice it.
  • On display
    You get a great view with our R1 displays. You get 1920 x 1080 Full HD resolution enhanced by IPS technology that produces vivid colours and a wide 178 viewing angle. You also get multiple display connectors to make it easy to connect.
  • A comfortable view
    Our R1 displays are designed to help preserve eye health. Flicker-less design reduces eye strain from screen flicker. A Blue Light Filter reduces the negative effects of excess blue spectrum exposure, and our ComfyView reduces screen reflection.
Acer R271 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/377942
Energy Class
Class E
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
17.3 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100/240 V (50/60 Hz)
62.1 cm x 22.38 cm x 45.38 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class E
38 kWh
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 6-bit gamma, 72% NTSC colour gamut
62.1 cm x 22.38 cm x 45.38 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Input Voltage
17.3 W
17.3 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.4 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62.1 cm - depth: 3.37 cm - height: 37.17 cm , With stand - width: 62.1 cm - depth: 22.38 cm - height: 45.38 cm
Sustainability Information
ENERGY STAR Certified
