- Acer R241Y - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class D
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 12.5 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 100/240 V (50/60 Hz)
- Black
- 53.98 cm x 22.38 cm x 40.5 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class D
- 32 kWh
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Backlight Technology
- LED backlight
- Black
- 53.98 cm x 22.38 cm x 40.5 cm - with stand
Audio
- Speakers
- VGA , DVI , HDMI , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Input Voltage
- 12.5 W
- Power Consumption SDR (On mode)
- 12.5 kWh/1000h
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.4 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
